Solved
Radeon 6950 Display Problem
Hey guys, I was hoping somebody could point me in the right direction to help me solve this problem. So I just got a Radeon 6950 video card off of newegg and I received it today. I uninstalled the nvidia drivers then powered off my computer and unplugged it.
I opened the case and replaced my old 9600GT with the new Radeon 6950 (which is huge btw) and plugged everything back in. When I power on my computer, I get no display on my monitor, and 1 of 2 things will happen.
1.) If I put my DVI cable in the top slot, then flip the power switch on, my computer turns on and off until I power it down by flipping the switch off.
2.) If I use the bottom slot, I get no display on my monitor but my PC powers on only when I press the power button and everything will be fine, then I hear a normal beep which was there even with my 9600GT, but after a few seconds the fan speed of everything except the video card slows down significantly and it does not stop until I power it down.
I'm not sure what the exact problem is, I have two ideas, the first is that my power supply is not powerful enough, which makes a lot of sense because I have the worst brand ever and to top it off, it isn't that powerful to begin with. The second is my case itself, it is a very tight fit and was fairly difficult to get the radeon 6950 to fit in the slot in the first place.
Everything is inside of my Vostro 200 Minitower which I bought 5 years ago, I made some small adjustments though. I replaced the power supply that came with it with a DiabloTek PHD550 back when I bought my PC, which was the biggest mistake in the world. I also added 2 GB DDR2 RAM so now it totals to 4 GB, and I purchased a 9600GT to replace the integrated graphics.
My case size is:
Height: 36.2 cm (14.2 in)
Width: 17.0 cm (6.7 in)
Depth: 43.5 cm (17.1 in)
If I had to make a guess, the issue is with the power supply. My 9600GT draws about 118W on full load if I recall correctly, and the radeon 6950 draws about 160 idle. Also, would anybody recommend a good power supply and case replacement that I could go with? I really hate how tiny my case currently is.
I was thinking of getting this:
- http://www.newegg.com/Product/Product.aspx?Item=N82E16811129181
And one of these two:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182133
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153136
Any better suggestions would be great, thanks!
3 answers Last reply Best Answer
More about radeon 6950 display problem
  1. Best answer
    Take your pick full tower and mid tower cases i recommend for PSU the Rosewill HIVE you linked is good ;)
    CPU:Rosewill THOR V2 Gaming ATX Full Tower Computer Case, support up to E-ATX / XL-ATX, come with Four Fans - 1 x Front Red LED 230mm Fan, 1 x Top 230mm Fan, 1 x Side 230mm Fan, 1 x Rear 140mm Fan
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811147053#top
    Case:Antec Twelve Hundred V3 Black Steel ATX Full Tower Unbeatable Gaming Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129100#top
    GPU:Thermaltake Chaser MK-I (VN300M1W2N) Black SECC ATX Full Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811133191#top
    Case:COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full Tower Computer Case with USB 3.0, Black Interior and Four Fans-1x 230mm front RED LED fan, 1x 140mm rear fan, 1x 230mm top fan, and 1x 230mm side fan
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160#top
    Case:COOLER MASTER CM Storm Series Trooper (SGC-5000-KKN1) Black Steel / Plastic ATX Full Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119245#top
    Case:NZXT SWITCH 810 Matte Black CA-SW810-M1 Steel / Plastic ATX HYBIRD Full Tower Gaming Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811146095#top
    Case:NZXT Phantom PHAN-001BK Black Steel / Plastic Enthusiast ATX Full Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811146068#top
    CPU Cooler:COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225#top
    Case:Antec DF-85 Black Steel / Plastic ATX Full Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129087#top Case:COOLER MASTER HAF XM RC-922XM-KKN1 Black Mesh, Plastic, Steel ATX Mid Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119257#top
    Case:Corsair Carbide Series 400R Graphite grey and black Steel / Plastic ATX Mid Tower Gaming Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811139008#top
    Case:Antec Nine Hundred Black Steel ATX Mid Tower Computer Case with Upgraded USB 3.0
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021#top
    Case:COOLER MASTER RC-692-KKN2 CM690 II Black Steel ATX Mid Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216#top
    Case:NZXT Apollo Black SECC Steel Chassis ATX Mid Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811146025#top
    Case:Antec Eleven Hundred Black Super Mid Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129178#top
    Case:COOLER MASTER HAF 922 RC-922M-KKN3-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case with USB 3.0 and Black Interior
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197#top
    COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
  2. Diablotek makes some of the worst power supplies on the market, but you don't have the worst, because I do. One of my computers has a 680W PSU that puts out less than 350W. I would upgrade it to something of higher quality. Of those 2 units, I would go with the Rosewill.
    The Seasonic 620W unit is one of the best on the market and would be great. Corasir also makes good ones.
    That is in fact a really nice case.
  3. Best answer selected by the_thr34t.
Graphics Cards Radeon Graphics Product Displays
