Solved
Gaming PC Parts (Need Advice)
Last response: in Systems
Hello
Early this year I posted a list of gaming PC parts. I am currently saving up for it and I just needed a good to go for it. Please let me know if I am missing something or something will not fit. Any reccomendations would be greatly appreciated :bounce:  . I am willing to add until it amounts up to $1500
Cheers
bs8814
Case:
BITFENIX COLOSSUS BLACK GAMING CASE $195
http://www.ple.com.au/ViewItem.aspx?InventoryItemID=608...
Motherboard:
ASUS P8Z77-M DESKTOP MOTHERBOARD $120
http://www.ple.com.au/ViewItem.aspx?InventoryItemID=609...
CPU:
INTEL CORE i5 3470 IVY BRIDGE 3.2GHz 6MB RETAIL BOX $200
http://www.ple.com.au/ViewItem.aspx?InventoryItemID=610...
PSU:
ANTEC TRUEPOWER NEW 750W SEMI-MODULAR PSU $145
http://www.ple.com.au/ViewItem.aspx?InventoryItemID=601...
HDD:
SEAGATE BARRACUDA 3.5" 2TB 64MB 7200RPM $120
Graphics Card:
XFX HD6870 DUAL FAN 900M/4200M 1GB/D-DVI/HDMI/m-DP $180
Sound Card:
ASUS XONAR DSX 7.1 PCI-E SOUNDCARD $55
RAM:
G.SKILL 16GB KIT DDR3 RIPJAWS Z C9 1600MHz $130
Total: $1145
More about : gaming parts advice
Thats One Good Looking Case you have there hahaa always wanted one of those.
MmmI really Dont know what you are Gonna Do with this Pc, but Thats one Hell Of a Overkill On the power Suply and Memory Ram. I would Go with 8Gb and Invest More on the Cpu or Video Card. Also Go with the 650w Version of that Power Suply Trust me With the New Ivy Bridge Power Saving Series you Wont even Reach 500w
Best solution
Looks good to me get a better GPU though 6870 is a weak card i would recommend nothing less than a 7870 although a GTX 670 would be better downgrading your PSU is never a good idea it's always better to get more than you need for breathing room and somewhat future proofing.
Ask the community
