This is an i7 3930k, Well I've somewhat fixed it so it doesn't shut down every 30 minutes(It's already shut down twice due to high temps, spread over I'd say a 3 hour period), so I shut down, waited an hour or so, took off the H60, reapplied thermal paste, and reinstalled the H60 and screwed it in TIGHT.
Then when I restarted I checked idle temps and they ranged anywhere from 41-43(most common) to 50C at times(rare). I added an extra fan on the case side to blow air on the CPU area(Before this I had 2 fans, one with the H60 and another blowing towards the GPU), is there anything else I can do.
Thanks
Thanks
