Solved
NEED HELP! BUYING NEW PC TODAY!
Approximate Purchase Date: e.g.: TODAY OR TOMORROW
Budget Range: AS LOW AS POSSIBLE
System Usage from Most to Least Important: WORD, EXCEL, SURFING THE INTERNET. THATS IT ! NO GAMING
Are you buying a monitor: No
Parts to Upgrade: I CAN ONLY REUSE THE CASE
Do you need to buy OS: No
Additional Comments: UPGRADING ONLY BECAUSE MY OLD COMPUTER BROKE DOWN. I HAVE A REALLY LOW BUDGET.
9 answers Last reply Best Answer
More about need help buying today
  1. Ok and how low is this budget? you have to elaberate a bit more
  2. sorry not used to forums...
    well, 300$ maximum.. i really dont need a powerful PC... but something that can work office properly... and windows xp
  3. If your budget is really low you could probably just get a used PC off ebay, that's what i would do in your situation anyway. And what specifically broke down on your computer?
  4. Intel Pentium G620 $63.99
    http://www.newegg.com/Product/Prod [...] 6819116399
    ASRock H61 DGS LGA 1155 Micro ATX Motherboard $49.99
    http://www.newegg.com/Product/Prod [...] 6813157315
    Western Digital Caviar Blue 250 GB $69.99
    http://www.newegg.com/Product/Prod [...] 6822136771
    Kingston HyperX Blu 4GB $23.99
    http://www.newegg.com/Product/Prod [...] 6820104238
    Antec EarthWatts Green EA-380D $44.99
    http://www.newegg.com/Product/Prod [...] 6817371033
    Rosewill Challanger U3 $39.99
    http://www.newegg.com/Product/Prod [...] 6811147060
    SAMSUNG DVD BURNER $14.99
    http://www.newegg.com/Product/Prod [...] 6827151244
    this is around 300$ and will give you a pretty dang good experience but it might be a couple bucks more
  5. crap links arn't working.. ummm let me get you some working links
  6. Best answer
  7. Thank you so much
  8. Best answer selected by pjleduc.
  9. no problem have fun with your build :D
New Build Systems Product
