Modding NZXT Switch 810
Last response: in Components
iceclock said:
it says there to use acrylic paint id go with that and remember:
Use a primer and paint from the same manufacturer for the best results, and never mix lacquer with acrylic enamel, pick one system or the other
So if I go with acrylic, will that go cover both metal and plastic parts?
