I finished my computer build! Few problems
I finished my first PC build! :bounce:
Intel Core i5-3570K 3.4GHz Quad-Core Processor
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/AM3+
ASUS Maximus V FORMULA LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard
Mushkin Enhanced Blackline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model 996995
Western Digital Caviar Black WD2002FAEX 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
OCZ Agility 4 AGT4-25SAT3-128G 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
EVGA GeForce GTX 670 FTW 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
COOLER MASTER CM Storm Series Trooper Black Steel / Plastic ATX Full Tower Computer Case
CORSAIR Professional Series HX650 (CMPSU-650HX) 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
LITE-ON 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM 8MB Cache SATA Blu-ray Burner with 3D Playback, LightScribe Support
Asus VS248H-P 24.0" Monitor
Microsoft Windows 7 Home Premium SP1 64-bit
I'm having a few problems. I have 2 hard drives, the SSD which I installed the operating system on and the 2TB HDD. I set the 2TB HDD as Drive E but it says System, Reserved (E:)  and only has 99.9MB available.
The other problem I'm having are the SATA connectors inside the case. The Asus Maximus motherboard came with 4 SATA connectors but they don't click when you plug them into the hard drives. You can pull them out with very little force. I can't put the side of my case on because it rubs up against them and they come right out. I think it's weird that all 4 have a loose fit in my hard drives. I hope it's not the hard drives. :(
Other than that, it seems to be running nicely. I don't know if it's just me trying to get used to the monitor but it's very contrasty. The green in the Google Chrome icon is sharp lime green. Probably need to mess around with it a bit.
I'm sure I'll run into other problems but that's about it for now. :)
Thanks for helping me get this thing built. Hopefully someone can help me out with the problems I mentioned.
Ask the community
