My CPU says my sond device is working properly, but no sound?
Last response: in Components
- my device manager shows sound card and says is working properly but when i click on the speaker icon bottom right it says hard - Tech Support
- My dell inspiron 15 laptop wireless is not connecting. The light is on and the device manager says it is working properly. Ho - Tech Support
- Device mgr says Nvidia card is working properly, but no signal to monitor - Tech Support
- My computer says audio device on high def bus not working properly - Forum
- Dvd says device is working properly but did not start a related device driver - Forum
- Installed xp pro on an emachine and sound quit working. says no sound device Forum
- my computer that i built is powered on and works but when i turn it on it says reboot and select proper boot device or insertb Forum
- Mobo says "Reboot and select proper boot device" on startup. Does this mean I haven't routed the HDD properly? solution
- Solvedi have my new hdd but it says Help "Reboot and Select proper Boot device or Insert Boot Media blah2" solution
- SolvedMy Laptop given message as below:This device (Seagate Backup Plus Desktop) is not working properly because Windows cannot load solution
- USB Flash Drive Suddenly "Empty" -- Windows sees it, says working properly, but can't access it. solution
- SolvedAsus splash screen says heatsink isn't working properly solution
- SolvedDevice not working properly? Ethernet Controller, PCI Simple Communications Controller, Microsoft ISATAP adapter. solution
- I have onboard sound card but xp says no audio device installed. code 10, no multi-media controller driver installed solution
- SolvedComputer says "Reboot and select proper boot device." Forum
- Solvedi replaced my hard drive and my computer says reboot select proper boot device and it wont do anything no matter which button solution
- Solvedsays, reboot and select proper boot device. Or insert boot media in selected boot device and press a key. solution
- SolvedSays says, reboot and select proper boot device. Or insert boot media in selected boot device and press a key. solution
- How to fix 'Code31: "This device is not working properly because Windows cannot load the drivers required for this device." solution
- How to fix laptop that says reboot and select proper boot device or insert boot media in selected boot device and press a key solution
- More resources
Read discussions in other Components categories
