First time builder need help!
Hey guys so i dont know how to delete my other post but ive decided i will build my own computer since many are saying its cheaper. The problem is i dont know that much about computers like im not completely in the dark but i basically know the basics. So i live in Canada so would be using newegg.ca
I basically want to be able to play bf3 on max and diablo 3 (im assuming if bf3 was maxed then diablo 3 could easily be played)
Im looking to stay around the 1000 dollar area if possible..
So i chose some parts idk if i got every part and i dont even know if they are compatible. If i could have some opinions and or help to possibly make it cheaper? Let me know! Thanks guys i really appreciate it.
Case:
ANTEC 1200 v3 -$180
Newegg.ca - Antec Twelve Hundred V3 Black Steel ATX Full Tower Unbeatable Gaming Case
Processor
Core I5-2500K- $225
Newegg.ca - Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
Motherboard
ASUS P8Z68-V PRO- $200
Newegg.ca - ASUS P8Z68-V PRO/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Power Supply
Corsair HX Series HX750-$ 145
Newegg.ca - CORSAIR HX Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
Ram (Memory)
G Skill Ripjaws Series 8gb (2*4)- $45
Newegg.ca - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
Graphics Card
EVGA 02G-P4-2678-KR GTX 670 $408
Newegg.ca - EVGA 02G-P4-2678-KR GeForce GTX 670 FTW 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
I know i dont have a hard drive or windows or a disc drive ill need help with that too :S
I know its alot of help to ask for but im seriously buying the parts and im relying on this community for support! Thanks guys
1 answer Last reply
More about first time builder help
  1. Hello!
    First of all- you should try to clean up your post. Cutting down to productnames will do.
    Seems to me its an okay setup. The PC will probably run battlefield 4 without problem. (no typo :P)
    So if you goal is only running D3 and BF3, you wont need a PC this powerful. The PSU, the RAM and the mainboard is maybe with too many features you wont notice anyways.
    My suggestions:
    Buy 1333mhz RAM, its real cheap now, and you wont notice any difference between that and 1600.
    Buy a cheaper mainboard and smaller PSU.
    Get a 120GB samsung 830 SSD for OS, and a cheap TB-harddrive for stash.
    You could maybe build a PC capable of running BF3 in a Mini tower. I would then recommend "Silverstone Temjin TJ08-E" In that case, youll have to choose other components.
New Build Systems
