Wont start, help
Just built, I turn on and press power button and turns on then right off, im lost
11 answers Last reply
More about wont start help
  1. Can I please have your computer specs? Do you hear any beeps when you turn it on?
  2. I5-357Ok cpu
    Asrock z77 Extreme4
    Gskill Ripjaws Series 2 x 4gb
    OCZ 750W psu
    Samsung 830 120GB SSD
    Western Digital 1TB
    I took off the System Headers, took off hard drives
    It turns on, the Intel Fan not turning, turns write off
  3. drillsar said:
    I5-357Ok cpu
    Asrock z77 Extreme4
    OCZ 750W psu
    Western Digital 1TB
    By Intel Fan I assume you mean the CPU?
  4. YEs cpu fan. I was told to check if its seated properly it seems it is. I was told to use paste but there is paste already on cpu fan. im really confused.
  5. Ok mb socket pins damaged, now I hope microcenter replaces
  6. Well micro center wont return, I put a bbb complaint in to see. I know I put cpu in right, I think pins where messed up and I made it worse. I know some retailers who bring back software opened, etc. I will never buy from micro center again
    If you want, you can always buy from Newegg. I love them! And can you physically see the pin bent?
  8. Im going back tm, there is nothing on receipt that tells me this. Yes I can see it now, there is like 2. Im wondering if cpu is also bad. I will give them hell tm. Asrock said they will charge $50 but I wonder if I have no warranty now. The box look opened when I got home, but didnt really look at socket. Micro center is cheap and I think this is why. So if you buy a computer and key breaks, etc they wont return it.
  9. I filed a dispute with my credit card, contacted bbb, contacted micro center on facebook, contacted there corporate office, next I will call shame on you, newspaper. I think I should get some action now
  10. Erm. I really would suggest going with NewEgg next time.
  11. yes i am, no more micro center for me. They will lose a lot, i see im not the only one with problems. Only way you get anywhere is call the corporate office which took me 3 hours of emails to finally get. Not sure if allowed to post that though
New Build Power Systems
