First mATX Build Questions
So I want to build a small decent rig for some gaming and light video editing/media. This is what I've narrowed down the build to:
Case: Bitfenix Prodigy
PSU: Corsair TX750V2
Motherboard:ASRock Z77E-ITX Mini ITX LGA1155
CPU: Intel Core I5-3570K Ivy Bridge
Hard Drive: Western Digital 1TB Caviar Black
GPU: Gigabyte Radeon HD 7870 OC
RAM:Corsair Vengeance 8GB Low Profile
CD/DVD Drive: Asus 24xDVD-RW Serial ATA Internal OEM Drive
Monitor: ASUS VS248H-P
Now I'm wondering about cooling in a smaller case. Am I going to need extra cooling hardware other than the stock case fans? I don't plan to overclock. I'd be open to some simple and easy liquid cooling as I've never done it before. If I do need some other cooling options what are some suggestions for decent quality quiet fans? What about a processor cooler such as the Cooler Master 212 EVO or some sort of GPU cooler?
And lastly is the RAM I've chosen going to fit / a good choice?
Thanks!
3 answers Last reply
More about first matx build questions
  1. the prodigy isnt as small as you think. its only a bit smaller than a matx case
    what is your budget and what parts do you not need? i can probably build a better Matx build
  2. There are very good m-ATX cases that cool well
    mini-ITX needs even more careful design
    so Id check out the silverstone TJ 08e case and see if it is small enough for you
    Either way you do not need a 750 watt psu . You should be fine with a good quality 500 - 550 watt unit
    Thanks!
    *Get a samsung Spinpoint F3 1TB, the caviar black is not worth it http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
    *750w is simply overkill for your components, get this PSU http://www.microcenter.com/single_product_results.phtml?product_id=0380192 its only 50$ after the MIR and its quality is simply outstanding.
    *Low profile ram always fits, good choice!
    *Idk if you are short on space but a decent mid tower case like the HAF 912 would be a bit better, you can also buy a few red led fans to make it cooler (in both ways ;)) and its only 50$!!
Build Systems Product
