Are These System Parts Compatible?
  • Homebuilt
  • Systems
  • Product
Last response: in Systems
August 8, 2012 9:37:13 PM
Case: Cooler Master Storm Enforcer
http://www.amazon.com/Cooler-Master-Enforcer-Interior-S...
Motherboard: Gigabyte LGA 1155 DDR3 1600 Intel B75
http://www.amazon.com/Gigabyte-Intel-CrossFireX-Motherb...
Power Supply: OCZ ModXStream Pro 600W Modular
http://www.amazon.com/OCZ-ModXStream-Modular-Performanc...
CPU: Intel Core i5-3570K Quad-Core Processor
http://www.amazon.com/Intel-Core-i5-3570K-Quad-Core-Pro...
CPU Fan: Cooler Master Hyper 212 Plus
http://www.amazon.com/Cooler-Master-Hyper-Sleeve-RR-B10...
GPU: ASUS HD7850-DC2-2GD5 Radeon
http://www.amazon.com/HD7850-DC2-2GD5-DisplayPort-Utili...
Optical Drive: ASUS 24xDVD-RW Serial ATA Internal OEM
http://www.amazon.com/Asus-24xDVD-RW-Serial-Internal-DR...
RAM: Corsair Vengeance 8 GB ( 2 x 4 GB ) DDR3 1600 MHz (PC3 12800)
http://www.amazon.com/Corsair-Vengeance-240-Pin-Platfor...
-or-
Win7 OS + 8GB RAM Bundle:
http://www.amazon.com/Microsoft-Windows-Home-Premium-64...
SSD: OCZ 90GB Agility 3 SATA 6Gb/s 2.5-Inch
http://www.amazon.com/Agility-2-5-Inch-Midrange-Perform...
HDD: Seagate ST2000DM001 Barracuda 7200RPM 2 TB SATA 6 GB/s
http://www.amazon.com/Seagate-ST2000DM001-Barracuda-3-5...
Please Help me Guys, i want everything to be compatible!
-JP
More about : system parts compatible
a b B Homebuilt system
August 8, 2012 10:25:11 PM
Check your messages http://www.tomshardware.com/forum/forum1.php?config=tom... i left you something there :D
Why are you only buying parts from amazon?? anyways, there are a few things about your build that can be changed:
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Amazon)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($134.99 @ Microcenter)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($43.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($82.99 @ SuperBiiz)
Storage: Samsung 830 Series 128GB 2.5" Solid State Disk ($89.99 @ Newegg)
Video Card: Diamond Radeon HD 7870 2GB Video Card ($254.99 @ Newegg)
Case: NZXT Tempest 410 Elite (Black) ATX Mid Tower Case ($85.98 @ Newegg)
Power Supply: Corsair 650W ATX12V / EPS12V Power Supply ($79.99 @ Newegg)
Total: $992.90
Ps: i dont know the exact cost of the stuff you linked and i know that my build is probably a bit more expensive but its worth every penny!
m
l
August 9, 2012 4:19:53 AM
get parts from newegg. It is usually cheaper, even if you have prime. Also if you are getting 8gb of ram with the os, don't buy more. You will save 40-50 if you do. No game requires more than 4gb of ram, and 8gb is usually the recommended for even the best gaming build.
m
l
August 9, 2012 6:27:24 AM
Uh Thanks For The Tips Guys, But the question is are the parts COMPATIBLE?
m
l
August 9, 2012 6:34:22 AM
Yes, they are compatible, but not because they are compatible means you have to get them, buy the build i listed.
Read your messages. ---> http://www.tomshardware.com/forum/forum1.php?config=tom... or at the top right colum
m
l
August 9, 2012 6:38:07 AM
i saw your private message dude, and i replyed to it?
m
l
August 9, 2012 6:38:55 AM
Also idk dude, i've been researching my build for 2 weeks now, i think its pretty solid... But ill use your websites for better prices, Thanks!
m
l
August 9, 2012 6:59:31 AM
hmm...to be honest (i dont want to sound arrogant) but my build is way better than the you picked....
Edit: nop, you didnt reply my message.
m
l
