Approximate Purchase Date: e.g.: This month
Budget Range: Up to 1100 with shipping perferablely
System Usage from Most to Least Important: gaming, web, editing
Are you buying a monitor: No
Do you need to buy OS: No
Parts Preferences: Intel cpu i7/i5, GeForece Gtx Fermi
Overclocking: Maybe
SLI or Crossfire: Maybe later
Your Monitor Resolution: 1920 x 1080
Additional Comments: Case is going to be a NZXT Phantom while other parts can change freely
This build is 1006.93 any help improving will be much appreciated
Case NZXT Phantom
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146079
Intel Core i7-2600 Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 2000 BX80623I72600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115071
CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
Kingston HyperX 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K2/8GX
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104173
EVGA SuperClocked 012-P3-1573-AR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130622
Or (not sure what the difference is here)
EVGA 012-P3-1570-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130593
ASRock Z75 Pro3 LGA 1155 Intel Z75 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157304&Tpk=asrock%20z75%20pro3%20lga%201155%20intel%20z75%20hdmi%20sata%206gb%2fs
Also what games you do think i could run with said rig or changed rig?
Overclocking: Maybe
Case NZXT Phantom
