Lights go on the MB - but system just does not start HELP!
Hello!
I've just built a new system with new power supply and when all plugged in, the motherboard lights up and all but once I hit on, the cpu fan and PS fan goes on for a split second then doesn't respond at all.
Board is M5A88-M
FX-8150
Rosewill Power supply
Any ideas?
Thanks!
6 answers Last reply
More about lights system start help
  1. Double check all power connections (24 pin board power, 6 (or 4) pin CPU power, fans, GPU). Also, check for any places in the case that could be touching the motherboard (standoffs, cables, loose power connectors, etc.)
  2. CBall means the 4 or 8 pin into the CPU (ATX/EPS) connection on the motherboard, there are no places for a 6 or 6+2 pin on the motherboard (that's PCIe) - just for clarification
    Thanks C12Friedman, so used to typing 6 pin for GPU (another big issue on Tom's :D )
  4. Hi
    Checked the things you guys suggested and still no go.
    Have also tried ONLY the mb (took out ram, sata drives, gpu, etc) and the same thing happens.
    Help!
  5. word?
  6. Try going through this sticky http://www.tomshardware.com/forum/261145-31-perform-steps-posting-post-boot-video-problems step by step... see if it helps
    Good luck
Power Supplies Light Motherboards Components
