Solved
Help in choosing a graphics card
I have a DH67CL motherboard with i3-2100 processor and Corsair Vengeance 4*2 GB ram,
I play games like assassins creed (the entire series) call of duty series and similar action games.
could you please suggest me which graphics card i could opt for
14 answers Last reply Best Answer
More about help choosing graphics card
  1. Need to know the make and model of your PSU and your budget first then i will be more than willing to help you
  2. Sorry for that,, I use a Corsair TX750 W PSU, my budget is $250 -$280
  3. n i'm having a Cooler Master CM 690 || Plus chasis
  4. Best answer
  5. I would go with AMD's HD7850 which is around 250$
  6. GPU:ASUS HD7850-DC2-2GD5 Radeon HD 7850 DirectCU II Video Card - 2048MB, GDDR5, PCI-Express 3.0 (x16), 1x Dual-Link DVI, 1x HDMI, 2x Mini DisplayPort, DirectX 11, Dual-Slot, CrossFireX, Eyefinity 6
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2297671&CatId=7387
    GPU:MSI R7850 Power Edition Radeon HD 7850 Video Card - 2GB, GDDR5, PCI-Express 3.0(x16), 1x Dual-link DVI-I, 1x HDMI, 1x Mini DisplayPort, DirectX 11, Afterburner, Overclocking
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2886170&CatId=7387
  7. Sorry just noticed both those Cards i linked are over your budget therefore i recommend this one http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2316882&CatId=7387 or this one GPU:MSI N570GTX Twin Frozr II GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127682
  8. the bus on the motherboard is PCI Express 2.0 x 16.. ryt ?
    So wld this fit in .. m a bit (or a LOTTT) low on the tech side..
    could u please guide me on this ..
  9. I'm using the same procie and I pick GTX 560Ti. Good price and performance and would last for 2 or 3 years from now.
    Yes, it will fit. The PCIe 3.0 graphics cards are backward compatible & will work with PCIe 2.0 slots.
    Yes the GTX570 or R7850 i listed will fit :)
    +1 he answered your question same as i would have ;)
  13. It seems you can get better prices at newegg. Most of their hd7850's are at your budget.
  14. Thanq every one .. thnx for ya support :) have a nice day :)
Graphics Cards Games Motherboards Graphics Product
