Solved
$1200 Gaming System Build "Need of Advice" PHILIPPINES
Approximate Purchase Date: Within the month
Budget Range: 50,000PH or $1200
System Usage from Most to Least Important: Gaming, Watching Videos, Work
Parts:
Intel Core I5-3450 (3.10GHZ)
MSI H77MA-G43 Intel H77
Kingston 8GB DDR3 1600MHZ
Western Digital 500 GB SATA 3.0 7200RPM CAVIAR BLUE HD
SILVERSTONE STRIDER Essentials (ST50F-ES) SLI 80PLUS 500WATTS POWER SUI
ASUS ENGTX560 TI
WIN 7 PROF 64BIT
SILVERSTONE REDLINE 01
Preferred Website(s) for Parts: PC Express PH
Country:Philippines
Overclocking: No
SLI or Crossfire: Yes
Monitor Resolution: 1366 x 768
Additional Comments: I would like to know if the stock cooler of the case is enough for this build and if i need to change certain parts of my build if, for example, any of you has had a bad experience with a certain part.
Games: Diablo 3
BF 3
CS:source
Etc.
7 answers Last reply Best Answer
More about 1200 gaming system build need advice philippines
  1. Best answer
    Get rid of windows Prof and stick with home premium. If you can squeeze in an extra few dollars consider getting a HD7850 it is newer and performs better then a 560ti. The 7850 will max all games at your resolution.
    An i5 3570k would be another nice upgrade to your build just to balance it out. I.e higher turbo boost and what not. And if you every do decide to overclock (I know what you said above) you have the option.
    Other then that well balanced out.
  2. Best answer selected by Randomftw42.
    Since i have a very strict budget and the store doesnt exactly say, i wont be getting the HD7850 :( but i would like to know if the windows home premium is:
    1) supported by games mentioned and;
    2)if there is a huge difference between home and prof
    Yes, home premium works for all those games. The OS of my laptop is Win 7 Home Premium and I can play Skyrim, Mass Effect, CS: Source, BF3, Witcher 2, etc. Home edition, Professional, Enterprise, Ultimate just differs in the features bundled with them, in accordance to the name implied. (Enterprise is for businesses and Ultimate offers all features)
    One last question then ill stop bohering everyone... :P
    Is the stock cooler for my case enough to handle these kinds of hardware?
  7. If your not overclocking it will be completely fine, noisy, but fine.
    Coolermaster hyper 212+/Evo, is ideal and well worth the extra $30 ish. But it's only a nice bonus. Feel free to stick with the stock cooler :)
New Build Systems
