smiffie72
Hello,
Up until yesterday, everything was working fine. Turned on the pc this morning, it's old but still runs! And the graphics had reverted to onboard VGA, test coneections on the card, all fine, none had come lose. Checked in the system and there was an exclamation mark. So took out the old cd, installed old drivers and all fine.
But I did update the drivers a while back and seem to have misplaced them somewhere.
So went to the Sapphire site where there are hotfixes??? Anyway, chose my card, system and then 12.4 drivers, but on installing the new drivers, there is an error with the install saying 'Application Install:Install package failure' and when detecting my card, it detects a Visiontek HD 2600XT and installs the driver for that.
So I then have to uninstall the drivers and install the old ones from the disk which work fine.
Also noticed the catalyst software on the new install doesn't work either.
I've tried some of the older updates and it always seems to detect the wrong card with a package failure error.
Any ideas how I can update the drivers?
Cheers
auntarie
737
Seems like the 3650 is dead and the bios has activated the onboard because of that. Maybe it's time for an upgrade? There are a lot of cheap cards that have at least triple the performance of a 3650.
