basil439 :
www.youtube.com/watch?v=xuc3r81J2uo
This happened all of a sudden. Is my Graphics card dead?.
Config:
Acer ASpire 5740G
i5-430M
ATI 5650M
Thanks
Config:
Acer ASpire 5740G
i5-430M
ATI 5650M
Thanks
blade061188 :
Has anything happened to the laptop recently? a drop or a spill of some kind?
Could be the screen or the GPU. Does the problem change with different angles of the display? are your laptop's fans running? the GPU could be overheating too
basil439 :
thanks for the reply
Nothing mentionable happened..
No, the problem doesn't depend on the angle
the problem is still there, if i switch the laptop on after switching it off for an hour.
one thing which is not noticeable in the video is the appearance of random letters in random places on the screen
basil439 :
the good old loose connection.
blade061188 :
good, you got it figured out then?
basil439 :
but i dont know which component had been loosely connected, how do i close the thread?
Mousemonkey :
This topic has been closed by Mousemonkey
OK, It was not loose connection. But I figured out how to correct the problem whenever it happens: (1) Somehow login in safe mode (normal booting gives BSoD). (2) Run Prime95 while covering the fan exhaust with a pillow . Wait for CPU to shutdown. Tadaa, the problem is gone.
It's as if something get reset.Till now the problem has only appeared when I play FIFA 12.Any Ideas?
PS: Sorry for "reopening" a closed thread this way (don't know any other).The original thread is here
