Hi, I have a ASRock Extreme 4 mobo, which came with 2 CPU fan Connectors ( 4pins on one and 3 on other), power fan connector, and 3 Chassis fan Connectors (4pins/3pins/3pins).
So If I have 3 case fans, should I connect all 3 fans to the motherboard or should I connect to the power supply? Does it matter with one or another? (I read it somewhere that you can control fan speed if you connect them to motherboard?)
As far as I know, CPU fan is mainly for the heatsink (I don't get why do you need 2, is there a heatsink that has 2 connectors? maybe?), power fan connector is for powersupply. So If I connect all 3 fans to the motherboard, how would you connect them if you dealing with 4 or more fans?
If there a specific way that's better than another? Does it matter if you connect them to 4 pins or 3 pins?
Thanks...
Thanks...
