Tom's Hardware > Forum > Windows XP > Configuration & Customize > System does not "see" my SCSI card(/)
Archived from groups: microsoft.public.windowsxp.customize (More info?)
I have just apgraded my IBM Aptiva from W-98 to XP Home. I have a Hewlett
Packard PhotoSmart scanner attached via a SCSI card/cable and ithas worked
well utill this software update. All my USB devices work OK, but the
PhotoSmart scanner is defunct. There is power to the device and I have
disconnected the cable and unplugged and reseated the SCSI card...ZILCH! I
can not find any reference to a SCSI in any folder that I have looked in so
it seems that my system is unaware of the existance of the SCSI
card...HELP...Please!!
Regards, Gordon
Sponsored Links
Gordon, did you load the XP Drivers for the SCSI Card? You could
probably do it from Device Manager.
Rt click MyComputer>select Properties>Hardware>Device Manager>SCSI
Devices.
"Gordon" <Gordon@discussions.microsoft.com> wrote in message
news:488F954D-97A7-4166-81CA-8A6F9B8B8BE2@microsoft.com...
> so
> Regards, Gordon
Reply to Anonymous
- 0 +
Thanks Rich, I have looked at this as you suggest, but I do not seem to have
the SCSI driver anywhere...I will go to the HP site and update the software
package again and see if I have any joy.
Thanks for the pointer...Gordon
> Devices.
> > so
> > Regards, Gordon
Reply to Gordon
Gordon
You should go to the SCSI card manufacturer web site for drivers..
Mike Hall
MVP - Windows Shell/User
http://dts-l.org/goodpost.htm
news:17C4241B-0E28-4951-B68A-5248451DE7B3@microsoft.com...
> have
> software
>> Devices.
>> >Hewlett
>> > worked
>> > card...ZILCH! I
>> > in
>> > so
>> > Regards, Gordon
Reply to Anonymous
- 0 +
What Model SCSI card are you trying to use?
What Model PhotoSmart?
> so
> Regards, Gordon
Reply to bill
- 0 +
Thanks Mike I'll get the screwdriver out and check make/model of
th SCSI card...it's ages since I first fitted it, then try the maker...Gordon.
"Mike Hall (MS-MVP)" wrote:
> Gordon
> Mike Hall
> > have
> > software
> >> Devices.
> >> >Hewlett
> >> > worked
> >> > card...ZILCH! I
> >> > in
> >> > so
> >> > Regards, Gordon
Reply to Gordon
- 0 +
Bill...good question! As the previous reply suggested that I go to the
SCSI Manufacturer and see if I can get any joy I'll get the screwdriver
out and check the card for make/model. I'm using an HP PhotSmart scanner
model C5100A.
Thanks for the assist, Gordon
> > so
> > Regards, Gordon
Reply to Gordon
There are 1205 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
