Will the power system give power to all these parts?
Last response: in Components
December 26, 2012 3:06:28 PM
PCPartPicker part list: http://pcpartpicker.com/p/tIDL
Price breakdown by merchant: http://pcpartpicker.com/p/tIDL/by_merchant/
Benchmarks: http://pcpartpicker.com/p/tIDL/benchmarks/
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($199.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler ($19.99 @ NCIX US)
Motherboard: Gigabyte GA-Z77X-UD3H ATX LGA1155 Motherboard ($144.99 @ Newegg)
Memory: Samsung 8GB (2 x 4GB) DDR3-1600 Memory ($39.99 @ Newegg)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($89.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 660 2GB Video Card ($209.99 @ Microcenter)
Case: Corsair 400R ATX Mid Tower Case ($90.98 @ Amazon)
*****Power Supply: Corsair Enthusiast 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($69.99 @ Newegg)
Operating System: Microsoft Windows 8 Full (64-bit) ($99.99 @ Newegg)
December 26, 2012 3:08:03 PM
Also do I worry about thermal paste?
a c 1109 ) Power supply
December 26, 2012 3:43:59 PM
For a system using a single GeForce GTX 660 (non-Ti) graphics card NVIDIA specifies a minimum of a 450 Watt or greater power supply that has a combined +12 Volt continuous current rating of 24 Amps or greater and that has at least one 6-pin PCI Express supplementary power connector.
Total Power Supply Wattage is NOT the crucial factor in power supply selection!!! Total Combined Continuous Power/Current Available on the +12V Rail(s) rated at 45°C - 50°C ambient temperature, is the most important factor.
Overclocking of the CPU and/or GPU(s) will require an additional increase to the combined +12 Volt continuous current ratings, recommended above, to meet the increase in power required for the overclock. The additional amount required will depend on the magnitude of the overclock you are trying to achieve.
The Corsair Enthusiast Series TX650 (CP-9020038), with its combined +12 Volt continuous current rating of 54 Amps and with two (6+2)-pin PCI Express supplementary power connectors, is way more than sufficient to power your system configuration with a single GeForce GTX 660 Ti.
There should be a tube of TIM (Thermal Interface Material) included with the Cooler Master Hyper 212 Plus.
a b ) Power supply
December 26, 2012 4:00:00 PM
"Tube of Tim" would be a good band name.
December 26, 2012 6:14:21 PM
Does that mean I'm all set and I have a great power supply?
December 26, 2012 6:15:20 PM
And also the cords from the power supply will all fit perfectly into other parts
a c 243 ) Power supply
December 26, 2012 6:24:38 PM
Is the rebate important ?
The TX650 is a decent power supply but for the same $90 upfront cost you can get the fully modular , Gold rated Seasonic X 650
Well worth the $20
December 27, 2012 3:00:40 AM
Will the tx650 fit with my parts?
