Sound Card and Headphones
Hello,
I was looking at getting into a new sound card and a nice pair of headphones. So far I have collected some good information, however I would like some feedback.
Sound card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132020
Headphones:
http://www.newegg.com/Product/Product.aspx?Item=N82E16826402014
http://www.newegg.com/Product/Product.aspx?Item=N82E16826262102
My current budget is going to be some where around $100-130, I will be using them primarily for gaming. For example, I would like to be able to hear enemies footsteps and place where they are coming from. Please leave feedback on the headphones and sound card and recommend me something else if you wish! Thanks!
2 answers Last reply
More about sound card headphones
  1. the sound card looks good for your purpose, and as far as headphones go may i suggest turtlebeach? they are specially made for gaming and they can be decently priced.
    here:
    http://www.turtlebeach.com/product-detail/pc-headsets/ear-force-z6a/44
    Best of Luck,
    clok555
  2. The ASUS Xonar DG is a good card for its price; just note its PCI (The DGX is PCI-E).
    Of the headphones you listed, the Audio Technica AD700 is the best, but it lacks in the bass department.
    I personally fell in love with my Audio Technica ATH-m50's though; doesn't really excel in any particular area; very balanced and accurate headphones. Works very well with Dolby Headphone on my ASUS Xonar Xense, so I would expect similar performance when paired with the DG.
    http://www.amazon.com/Audio-Technica-ATH-M50-Professional-Monitor-Headphones/dp/B000ULAP4U/ref=sr_1_1?ie=UTF8&qid=1356861179&sr=8-1&keywords=ath+m50
    Plenty of other options though; I generally recommend to go to head-fi.org, as they have a TON of people who've used dozens of headphones.
Headphones Sound Cards Components Product
