Hello people.
I upgraded the motherboard, CPU, GPU and RAM in my PC.
Motherboard: Asus P8Z77-V Pro
CPU: i7 3770K
RAM: Corsair Vengance LP 16gb
GPU: Sapphire 6970
PSU: Corsair HX 750
The thing is when I started it and had all 4 RAM sticks in, the DRAM LED turns on and there's no picture on my screen. I took one RAM stick and started from left to right slots. The two left ones doesn't give me a picture, only turns on the DRAM LED till it turns off the system and on again. The two right ones works, which brings me to the next problem:
It goes to a screen which tells me windows couldn't start and it recommend doing a start up repair tool (Which takes ages and does not help), and the other option is to start as normal. I chose the second one and it says "Starting windows" and the colors goes in a circle to make the windows symbol, but the freeze up for a couple of seconds, and I get a tiny second with bluescreen and then it restarts doing the same procedure.
Is it the motherboards fault? What can I do. I really need my computer ASAP.
Help!
Excuse my english, I'm from Norway!
CPU: i7 3770K
GPU: Sapphire 6970
PSU: Corsair HX 750
Help!
