Solved
Configuring Sound Card
I just got my sound card today, it's an Asus Xonar DGX and was wondering what would be the best way to configure it. This is my first actual soundcard so was wondering some basic settings for the best possible results. I mainly play FPS games, I also listen to music as well mainly. A few brief questions:
How many channels should my setting be on? 2, 4, 6 or 8?
I am using a headset, should I select 'headphones' or 'speakers'? It's on speakers by default.
Sample Rate? PCM 44.1 khz, PCM 48, or PCM 96?
Also, when I go into my control panel and configure my speakers, should I select 5.1 or 7.1 surround?
Thanks for any input!
2 answers Last reply Best Answer
More about configuring sound card
  1. Best answer
    The number of channels should be set to 2, barring enabling Dolby Headphone (see below), as you headphones are stereo.
    When using a headset connected to the headphone amp, set the output to headphones. You can set the gain for the headphones as needed. (For most, no gain is required, though low gain can help drive volume on some headsets.) When using the 3.5mm output jack, set to speakers.
    Same rate really shouldn't matter, as the difference is negligable. Barring having an audio collection encoded as 96KHz, set to 48KHz and forget about this one. All this setting really does is set what the final output sample rate is, and you do add a VERY slight delay if the card has to resample the final output. Most audio is 44.1 or 48KHz anyway.
    Don't bother with the windows control panel; the speaker output setting is slaved to the 'Number of Channels' setting in the DGX's control panel.
    If you want to enable Dolby Headphone (basically, virtualized surround sound), set the number of channels to either 5.1 or 7.1, and enable the Dolby Headphone option (and optionally, the 7.1 speaker shifter).
  2. Best answer selected by zex_vex55.
Sound Cards Speakers Configuration Components
