Yes No
Ads
Tom's Hardware > Forum > Networking > VPN, Remote Connection, VoIP & Video Conferencing > Forwarding Network Printer via RDP (net use help)
Forum Networking : VPN, Remote Connection, VoIP & Video Conferencing Forwarding Network Printer via RDP (net use help)
i'm having a real issue getting a network Brother MFC-J615W multifunction printer to forward through RDP (using net use) to a windows XP VM from a Vista desktop.
So far, i've done all i know to do to get the printer forwarded:
I've shared the original printer in vista as "brother1"
created new printer in vista using LPT2, called it "remote"
opened a cmd prompt, typed in "net use lpt2: \\vistapcname\brother1 /persistent:yes"
received a "successful" reply
connected to the XP VM thru RDP and see all the other printers available on the Vista desktop
(printer sharing *is* enabled in the RDP connection profile)
(i've also installed the printer drivers on the Win2008 server and the XP VM)
any ideas?
Reply to bdubs85
Can I rephrase your issue?
Basically, you're trying to setup a printer as a network printer, share it and then add this printer into your XP VM which is running on your Vista desktop, correct?
Reply to bongoyoyo
I have a vista desktop with a networked (tcp/ip based) printer at a home location. the vista desktop connects to a XP VM at a remote location.
i'm having problems getting printer redirection to work so the vista desktop can print things from the XP VM to the home printer.
Reply to bdubs85
Open Remote Desktop Connection, go to options > Local resouces > Local Devices & resources > tick the check box for printer. That is if you are using RDC version 6.1.
The printer should be visible under Devices and Printers (Should say Printer Name (redirected) )
Reply to bongoyoyo
i've already done that long ago.
Reply to bdubs85
Which server or workstation is your printer installed on? Check it to make sure it's installed correctly and it's setup as share network pritner.
Reply to bongoyoyo
There are 2027 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
My desktops internet. HELP
By Realbeast, 1 day ago:
Sure could be a virus or malware, you should use a good free antivirus and...
Best offers
Top experts
