Geforce GTX 670 performance drops? PLEASE HELP
i have a ZOTAC Gefore GTX 670 AMP! edition and i dont seem to have stable performance while playing games. Im playing Deus Ex: Human Revolution, and even with normal settings, when i turn a corner, or look at alot of fire or something in-game, my fps drops to like 25-35 rather than 60 for a couple seconds. This kind of ruins the game as whenever you want to sneak around or turn a corner to shoot someone, you have a 2 second FPS drop every time you turn a corner. Why is this happening, i dont have all setting to max or very high even! i was expecting exception performance out of the 670, especially the AMP! edition and the fact that Human Revolution is not necessarily graphically demanding.
Is something wrong? what can i change to fix this??
the rest of my build:
i5-3570k
G.Skill 8gb Ram
1TB seagate barracuda HDD
ASRock Z77 Extreme4 Mobo
*nothing is overclocked or tampered with, i just assembled PC
Related ressources
well, i tried to reinstall the game thinking that it was the problem because other games didnt seem to have this issue, and in trying to do that i accidently DELETED THE ENTIRE GAME. I have to wait through another 4.5 hour download to even test it again. :fou:  :fou:  :fou:  :fou:
Graphics card Expert
i5-3570k
G.Skill 8gb Ram
if this problem is just for this game so your problem is drivers issue,if there are other games it must be power supply cheap power supply can cause lots of trouble ,if its not the power supply it must either the mother or the graphics card it self
adampcpower said:
OCZ Fatal1ty 750w. Please dont tell me thats the problem.. i just bought it
We'll one thing that comes to mind when I see a power supply with 4 vrails I think that perhaps you don't have the correct pci-e cables connected to it to feed it the proper vrail amps. Which is why I never suggest multiple vrail psus anymore.
I would think you would have this issue for more than just 1 intensive game. Perhaps try out some other gpu intensive games and see if same issues occur.
Are you sure about that? I always thought that the PSU adjusts the power through the rails itself.Also even at 216 watts per rail that's still enough to power a single GTX670.
Well if he has the wrong pci cables connected it could cause issues.
E.G. you would want to figure out how your vrails are managed, then connect the vrail dedicated to PCI to the gpu.
Some psus will dedicate 2 vrails seperately to two pci cables giving 432watts total for the two pci cables. Which would definately be enough for a single 670.
Graphics card Master
It is sufficient but you need to look towards the manual for which rails and connectors you should use.Although I doubt this is a power related issue because if the rail was using to much power it would just shut down entirely.What your experiencing sounds like a driver problem or a fault with the card itself.
Skip to the "Multiple +12 V rails" section.
http://en.wikipedia.org/wiki/Power_supply_unit_(computer)#Multiple_.2B12_V_rails
what else can i do to further diagnose the problem? should i just download another graphics intensive game and see what happens, or what? i want to narrow it down so i dont start worrying if my graphics card is defective, i would hate to have to RMA after i JUST got this comp up and running
Wow... so much misinformation...
I've seen kind of issue before and it usually ends up being a frame buffer problem. You're most likely exceeding the 1GB or whatever of VRAM that your card has.
If you have some kind of GPU monitoring ability see what the maximum VRAM use is. If it goes over, which will happen when you introduce new things to the scene (as in going around a corner), it will try to use the Hard Drive as VRAM which makes is stutter horrendously for a few seconds until it frees up enough RAM.
your describing exactly what happens. I will check shortly, but i'd hope the ZOTAC GTX 670 AMP! edition would have more than enough to process these situations, or why did i throw over $400 at something that wets itself everytime i turn a corner. Can I resolve this problem easily?
SPECS:
Engine Clock speed
1110 MHz (base),
1176 MHz (boost)
Unified Shaders
1536
Shader Clock
N/A
Memory Clock speed
6608 MHz
Memory
2GB GDDR5
Memory interface
256-bit
The 670 should have enough VRAM to handle a game like Deus Ex. However, there could be a driver problem that is causing the VRAM to be mismanaged.
I think your best bet is to follow Purple Stank's advice and sweep all your drivers and re-install the latest ones.
If that doesn't work, try some other intensive game and see if the problem occurs in that. If it does, it's probably a hardware issue and we can narrow it down from there. If it doesn't, it must be a software issue.
Ok, so i am going to delete and re-install all video card drivers and i am currently downloading FarCry2 (thats the most demanding game i currently have) and see how that plays. I will update within a couple hours, stay with me guys you've all been so helpful!
Ok, so heres the deal. I reinstalled the game as well as the drivers for the video card along with other games. For Diablo 3, everything runs perfectly on max settings, and for FarCry2, it seemed pretty flawless without noticible fps drops. For Deus Ex: HR, there still seems to be FPS drops when i turn corner, or sometimes at random and also its not as sever if its in windowed mode compared to fullscreen mode, even if i stretch the window to full. No matter what settings i have the game on, whether medium all or maxed out, the fps drops occur just as often and are just as noticible, probably from 60 to 30 fps for about 1 second. What do you guys think, im new to PC gaming so should i just expect FPS drops during a game?
adampcpower said:
well, in windowed mode, the game ran fine, but as soon as i went to fullscreen the FPS dropped off completely
Omg so much useless infos people posting here.If your game runs fine in windowed mode then its ovious driver issue.That game is anyways am amd game.
can this problem be fixed to make the game run better, or do i just live with it? as long as its not the GPUs problem and the actual hardware is ok then im good. i just want to make sure the component is working properly in case i had to return it or something
Im running nvidias driver 304.48 currently
Run crysis2,bf3,skyrim,heaven benchmark.What kind of framerate u r getting in far cry2?And let me tell you something you can never play every game flawlessly with a particular driver.You got to experiment with old drivers.
how do i run these benchmarks, do i have to buy all the games or is there another way.
And as long as the hardware is fully functional then im ok, as long a there is no defect in the actual component so i can rest assured all the money i spent isint wasted for something thats not working right
cooldudesubho said:
yup u have to buy them.but heaven is free.download that
I ran Heaven Benchmark and these were the results:
Powered by Unigine Engine
Heaven Benchmark v3.0 Basic
FPS:
47.7
Scores:
1201
Min FPS:
11.1
Max FPS:
126.4
Hardware
Binary:
Windows 32bit Visual C++ 1600 Release Mar 7 2012
Operating system:
Windows 7 (build 7601, Service Pack 1) 64bit
CPU model:
Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
CPU flags:
3399MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 HTT
GPU model:
Intel(R) HD Graphics 4000 8.15.10.2696 2112Mb
Settings
Render:
direct3d11
Mode:
1920x1064 8xAA windowed
Shaders:
high
Textures:
high
Filter:
trilinear
Anisotropy:
16x
Occlusion:
enabled
Refraction:
enabled
Volumetric:
enabled
Tessellation:
extreme
Are these results good, and why did it not recognize my GTX 670??
cooldudesubho said:
Looks normal.
overclockersclub.com/reviews/nvidia_gtx670/8.htm
you got virtu mvp installled?
they are normal? i looked at forums of others scores and other people got much higher, and nobody had as low of a min fps as i got.
And yes, i have VirtuMVP
ankydu said:
I myself looking for zotac 670 amp edition,but not able to find any reviews for it. Is your problem sorted now?
hello,
yes the problem is sorted, and i STRONGLY recommend the Zotac 670 AMP! edition. it is THE FASTEST gtx 670 card available on the market and has both superior cooling and a completely unnoticeable sound. I paid 409.99 for the card and i think it is the best price for technology that is basically at gtx 680 power
There are two things that i recommend to get the BEST experience out of your card though. First, uninstall and avoid Lucid Virtu technology. I am not sure if it is because of the Zotac card specifically or the gtx 670s in general, but it will mess up the performance of your card (it is the cause of the problems i had). SECONDLY, the card itself is SO BEEFY that it cannot support itself...(im not sure why but most reviewers also point out this issue). near the back corner the entire card starts to droop and need additional support to ensure it dosent break anywhere. Personally, i propped up a very small bamboo pole that i painted black so that you cannot even see it and it works fine.
overall, i urge you to get this card if you are looking for the highest performance with it nipping at the heels of 680 cards but for $100 less. I love the freedom to any PC game on the market and know i can run it at ULTRA settings and at 60 fps
(ALSO, check out the "battle of the 670s" review of all 670 card on TomsHardware. It is very comprehensive and gives a good review of each card compared to the others) http://www.tomshardware.com/reviews/geforce-gtx-670-tes...
Never run your onboard and dedicated graphics at the same time bro.
Lucid Virtu is for onboard, disable when you install dedicated card. Voila
Its a problem for anyone :p
As for the decision of what 670 to go to,
My main 2 things when looking for a card is
1. Performance
2. Price
My 2 wants from a card
1. Warranty > 1 year
2. Matching color scheme
TF4 / DCII TOP / AMP! / Windforce all great models that perform very well.
I myself run two EVGA GTX 670 Vanilla cards because I ordered one right when it first released and was so impressed I ordered another. (They came with the high airflow bracket so they stay cooler than other EVGA 670s plus I installed the backplates for them so even better temps.) Personally my BF3 1080p 4xMSAA FXAA Vsync 60fps runs at 43C to 55C with 50C being norm. That is rediculous imo and beats my two Twin Frozr III 6950s badly at gaming temps.
I like the vanilla evga 670s because of the HFB (highflowbracket) and the fact that they exhaust directly out the back of the case plus you can buy 5 to 10 year warranties for them.
1. Performance
2. Price
for literally $10 more you can dramatically increase the performance of the reference card. My ZOTAC AMP! has a huge metal heatsink and awesome looking and useful copper pipes with very quiet fans that let me card not exceed about 42 C with prolonged gaming load. Also, the nearly 1098 mhz clock speed and 1176 boost clock kick reference cards butt and is at the same level as a 680 card.
Thats nice and all but imo the thing is mega ugly for most peoples rigs. My cards can run 1200mhz core np but yours definately runs cooler :p
Now grab a 2nd card and really go to town :D
adampcpower said:
hello,
Thanks for you reply. Now I am sure its a great performing card. But now u ve put me another confusion. :o  I have a i7 rig with Massive Noctua NH-D14 already testing the strength of my Asus p9x79pro motherboard. So I really m not sure if its a wise idea to add this zotac monster as well. :cry:
if you have a way to add additional support to the back end of the card then it should be no problem at all. Like i did, just adding a stick or two cut to the right length to prop it helps tremendously. also, you could fashion a string to tie it up. there are plenty of ways to keep the card up and if you do it will not hurt to add it to your system
Thanks for the reply. I almost forgot that I have a Gfx card support module available with my HAF X cabinet. :D  . That should do the trick. :sol:
Ask the community
