D da2nkusdinar Honorable Dec 27, 2012 1 0 10,510 Dec 27, 2012 #1 type mother board biostar G41D3C Ver. 7.x
O o1die Illustrious May 16, 2001 14,175 0 42,960 Dec 27, 2012 #2 It means just what it says. If you cpu is over 95 watts, it may not run properly on that board. The cpu wattage limit is usually listed under "cpu support", but I haven't checked it. That's something you can do. Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,519 0 66,960 Dec 27, 2012 #3 if you have went and got a 125w cpu it wouldnt be a good idea to install it though might help if you made it clearer what you want to know Upvote 0 Downvote
