Help cabinet needed!!!
guys yesterday i got stuck while installing :fou:
1.asrock z77 exxtreme4
2.i5 3570k
3.corsair gs600 watt
in my old cabinet (4.5 years old....i know it's really old ;)
so please suggest me a cabinet
i'm from india..so suggestion from this site ( http://www.flipkart.com/ ) will be better.....
can wait to use my new school.............
4 answers Last reply
More about help cabinet needed
  1. Hmm..I dont really suggest buying from flipkart, you can find the prices in your local shops 500-1k lesser and even less. If you cant, well thats your option then.
    And for the case recommendation, after days of searching and searching for the same, I finally chose to buy a Corsair 400R. I am getting it for 4300 here locally and it seems to have more than all the features at that price.. Combine with a Coolermaster Hyper 212 Evo/+, I dont think any other combo can give this much cooling and features at this price..
    thanks for your recommendation but it is too much.....i want under 55 dollar (3000 rupees).......you can give me suggestion from other sites as i'll buy from retailer or local shops....
  3. Hmm..then corsair 300R. Im not sure of any lower price recommendation, cuz investing once on a good case is better. Dont try to buy Cooler master cases as they are way too costly in India..
    thank you.....i know investing once on a good case is better but i'm on tight budget...so waiting for more suggestion
Power Supplies Intel i5 Corsair ASrock Components
