Which Power Supply Is Better Overall?
  • Power Supplies
  • Performance Power
  • Components
  • Product
Last response: in Components
December 27, 2012 8:03:42 PM
Hi which power supply is the better one Overall?
1.) CORSAIR Enthusiast Series TX850 V2 850W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply (http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
OR
2.)OCZ ZX Series 850W Fully-Modular 80PLUS Gold High Performance Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom (http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
I looked at reviews for booth but cant decide.
Need someone else's opinion.
More about : power supply
a c 1218 ) Power supply
December 27, 2012 8:18:49 PM
My vote goes to the OCZ because it's fully modular and has 80PLUS GOLD efficiency.
m
l
December 27, 2012 8:44:53 PM
thats what i was thinking. i like that its fully modular.
but do you think the overall quality and performance for the OCZ is better than CORSAIR?
m
l
December 27, 2012 9:21:47 PM
About the same, they are both quality power supply units, the 80plus gold is a good option.
m
l
I prefer the OEM (i.e. Seasonic) that Corsair uses for the now discontinued CMPSU-750TXV2 that you've linked to.
OCZ uses an obscure OEM, Great Wall, for their OCZ-ZX850W.
Both models have a 5 Year warranty.
If you don't have much room in your computer case to hide the extra unused cables for the Corsair CMPSU-750TXV2 then get the OCZ-ZX850W.
m
l
