Problem with SABERTOOTH z77 Intel lan card
I have my whole build done. I installed the drivers from the cd that came with the motherboard, yet after many reboots and reinstalls of the LAN driver, i still cant get it to scan for a single wireless network. That might be the problem though, it might only be able to connect via ethernet cable, but i think an ASUS SABERTOOTH Z77 motherboard would bring a wifi feature with it...
Anyways, any ideas on what to do?
thanks in advance:)
3 answers Last reply
More about problem sabertooth intel card
  1. No wifi feature. You need a USB or PCI wi-fi card for that.
    http://www.asus.com/Motherboards/Intel_Socket_1155/SABERTOOTH_Z77/#specifications
    wow :(
    i can hook it up via ethernet cable right?
  3. Yes, you can.
Motherboards Components
