Will this card work for my pc?
CPU: Pentium Dual-Core E6500
RAM: 4GB
Will the graphics card below work with my pc?
& a new power supply
RAM: 4GB
More about : card work
stewie1million said:
CPU: Pentium Dual-Core E6500RAM: 4GB
fine, but why are you wasting your money on such an expensive card and about a cheap cpu.
JKatwyopc said:
There's nothing wrong with those choices for the Graphics card and PSU, however, what motherboard do you have? Do you have a PCIe 2.0 x16 slot available to plug the graphics card in to? That graphics card might be bottlenecked by that old of a CPU.This? http://i.1dl.us/vjv.jpg
Related ressources
- How do I fix my pc to work after getting a new video card ? - Forum
- Will my PC work with this Video Card - Forum
- Can't get miniPCIE wireless card to work in PC . Do I need antennas? - Forum
- Will this PC combo from Newegg work withouth 3D card ? - Forum
- Will My PC work with This Grpahics Card - Forum
@xtreme5: Don't forget he's planning on getting a new 550W PSU from Antec.
If you want upgrade your CPU as well as your GPU and stay within that budget, what you could do is get these instead of that video card:
XFX Radeon HD 7770 - $135
Intel Pentium G850 - $88
You could also spend a little more on Sapphire's VaporX version of the 7770 if you wanted to.
mousseng said:
@xtreme5: Don't forget he's planning on getting a new 550W PSU from Antec.If you want upgrade your CPU as well as your GPU and stay within that budget, what you could do is get these instead of that video card:
What's wrong with my current cpu?
It's a 115-230w... there's a switch on the back to change between the two.are you talking about this??
Uploaded with ImageShack.us
no, this is VOLT not watts. xtreme5 said:
are you talking about this?? ]http://img528.imageshack.us/img528/5000/volt.png
no, this is VOLT not watts.yes
MR, I know he need a new PSU not 550w 450w is enough.
xtreme5 said:
MR, I know he need a new PSU not 550w 450w is enough.If you know he needs a new PSU, then it's not hugely important that we know what his old one can do, yeah?
What's wrong with my current cpu?There's nothing wrong with your processor, but you simply won't be able to get the most out of that 560ti - that E6500 will hold it back ('bottleneck' it). By getting a Pentium G and a 7770, you'll end up with a much more balanced system - neither will be holding the other back too much.
mousseng said:
If you know he needs a new PSU, then it's not hugely important that we know what his old one can do, yeah?There's nothing wrong with your processor, but you simply won't be able to get the most out of that 560ti - that E6500 will hold it back ('bottleneck' it). By getting a Pentium G and a 7770, you'll end up with a much more balanced system - neither will be holding the other back too much.
Ok but that 7770 only has 1 dvi (I have dual monitors)
Best solution
Ok but that 7770 only has 1 dvi (I have dual monitors) and it requires a 450w power supply (i've got 350W)No trouble mate, we can fix that. Also, the Pentium/7770 idea still includes that 550W PSU you picked out. So here's what I'd get if I were you:
Sapphire VaporX Radeon HD 7770 - $150 (this one has two DVI ports! it's also runs cooler than the other)
Antec BP550 - $50
This totals out to $288 before rebates ($273 with rebates), and they all have free shipping. This costs right about what the 560ti + PSU costed, too.
xtreme5 said:
well, 350w enought for you gtx 560ti eats 202w at max load.No, no it's not at all. You have to account for the fact that it's probably less than 80% efficient (meaning it'll get 280W at most), and he's got a 65W CPU as well as other components (so we'll round that off at about 90W). Not to mention it's a horrible idea to push your power supply at close to its max load - you could cause it to fail and potentially destroy important bits, like the CPU or GPU.
mousseng said:
No trouble mate, we can fix that. Also, the Pentium/7770 idea still includes that 550W PSU you picked out. So here's what I'd get if I were you:Sapphire VaporX Radeon HD 7770 - $150 (this one has two DVI ports! it's also runs cooler than the other)
Antec BP550 - $50
Thanks i think i'm going to go with those three, going to be a lot more to install but well see how it goes.
xtreme5 said:
you can use dual dvi connector like this]http://img403.imageshack.us/img403/7167/dualdvi.png
Related ressources:
- ForumINTEL overclocking guide
- ForumDoes my PC with PCIe 1.0a x1 work with any graphics card ?!?
- ForumHi i wanna ask will GT440 DDR3 card work on my PC my motherboard is MG-630I-7019
- More resources
never touch with that thing if you change it to 230v your PSU will be blown up, so be aware of that thing. how many watt is that?
