I'm going for around a $900 build but have about $700 at the moment. I was thinking of just doing the build and purchasing a graphics card later on.
Case(119.99) - NZXT Phantom Full Tower - http://www.amazon.com/Crafted-Series-Tower-Steel-Chassis/dp/tech-data/B003WE9WQO
Motherboard(104.99) - ASRock Z68 PRO3 GEN3 Intel Z68 ATX DDR3 1066 Intel - LGA 1155 Motherboard - http://www.amazon.com/ASRock-Z68-PRO3-GEN3-Intel/dp/B005N5Q2MW/ref=sr_1_fkmr0_1?s=electronics&ie=UTF8&qid=1344784737&sr=1-1-fkmr0&keywords=ASRock+Z68+Extreme3+Gen3+LGA+1155+Intel+Z68+HDMI+SATA+6Gb%2Fs+USB+3.0+ATX+Intel+Motherboard
CPU - ($199.99 on Amazon, can get cheaper at MicroCenter) - i5-2500k - http://www.amazon.com/Intel-i5-2500K-Quad-Core-Processor-Cache/dp/B004EBUXHQ/ref=sr_1_1?ie=UTF8&qid=1344783595&sr=8-1&keywords=Intel+Core+i5-2500K+Sandy+Bridge+3.3GHz+%283.7GHz+Turbo+Boost%29+LGA+1155+95W+Quad-Core+Desktop+Processor+Intel+HD+Graphics+3000+...
Memory - ($50.45) - G.SKILL 8GB (2 x 4GB) Ripjaws X Series DDR3 1333MHz (PC3-10666) 240-Pin. Desktop Memory F3-10666CL9D-8GBXL - http://www.amazon.com/G-SKILL-Ripjaws-PC3-10666-240-Pin-F3-10666CL9D-8GBXL/dp/B004ISXB4C/ref=sr_1_7?s=pc&ie=UTF8&qid=1339645212&sr=1-7&keywords=ddr3
PSU - ($54.99) - LEPA B550-SA 550W SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply - http://www.newegg.com/Product/Product.aspx?Item=N82E16817194102&Tpk=lepa%20550
HDD - ($89.99) - SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Are these parts good/is this a good build?
Any ideas on a graphics card?
P.S. I hope to order most if not all of the parts from Amazon versus Newegg as I can get free shipping.
Thanks.
Thanks.
