Closed Solved
Sound Card Advice
Hello,
I am looking to buy a sound card for my PC. Which would you guys recommend between these two:
http://www.futureshop.ca/en-CA/product/asus-asus-7-1-pci-e-audio-card-xonar-dsx-xonar-dsx/10216262.aspx?path=7d88985cb030072cdcff1e1aaf34e9dfen02
http://www.futureshop.ca/en-CA/product/asus-asus-7-1-pci-e-sound-card-xonar-dx-xonar-dx/10216265.aspx?path=763d3d8154cf50c046f51b8233f81924en02
My motherboard is a Gigabyte GA-890GPA-UD3H revision 2.0. Will these sound cards work on my MB? Would I notice a difference in sound qualify if I'm using sound through http://steelseries.com/products/audio/steelseries-siberia-v2 ?
3 answers Last reply Best Answer
More about sound card advice
  1. i would go with the cheaper one if your not planning on doing any video or sound editing. is there no integrated sound on your Motherboard?
    Best of Luck,
    clok555
  2. Best answer
    I don't like the DSX that much; reviews actually preferred the slighter cheaper DGX over the DSX, and it probably doesn't justify the extra price (all of $10 or so).
    The DX is the superior card though, as the jump in quality from the DGX/DSX to the DX is significant.
    Regardless, you should hear a significant increase in audio quality using any of the above mentioned cards with any decent headset.
  3. Best answer selected by ecko69x.
Motherboards Gigabyte Sound Cards Components
