Hello,
I am building a computer from scatch and a friend of mine gave me a case. But the case front panel had some components remove and so I have to modify the front end to include a power switch. I did not have one so I took a switch from the rear of a bad ATX power supply and when I put the switch in the on position and get a open circuit then the pc boot up for 2 seconds and the power is kill. And I try to boot up again and it does the same thing. I want to use this front end switch on the front panel of my pc. Does anyone have a solution to this problem. Thank You ! David
