How to hook up fans on nzxt apollo
Hello,
I have 3 wires from the side fan and 3 wires for the rear fan. I have one spot on the mother board for system fan. where do I plug all the other wires.
2 answers Last reply
More about hook fans nzxt apollo
  1. natep said:
    Hello,
    Something like a molex fan splitter could be used. Basically you will use a 4 pin molex connector from your psu, and plug it into one of these: http://www.pcworld.co.uk/gbuk/dynamode-molex-fan-power-splitter-cable-0-10m-07843269-pdt.html?srcid=867&cmpid=comp~Google~Components+%26+Upgrades~07843269&istCompanyId=9a35962d-802d-4e67-9721-0a3328ca1f02&istItemId=qwitlpt&istBid=t
    You said you only have one spot on your motherboard, and as far as i'm aware, this is the simplest way to achieve what you want to do.
    thanks, I'll give it a try
Power Supplies Fan Motherboards Components
