So this is my first ever plan to build a computer. This computer will be primarily for gaming, but also for music, and web surfing. As I am not extremely knowledgeable with the inner workings of computers, I have some questions, and any help is appreciated.
CPU: $230 Intel i5 ivy bridge 3570k @3.4 ghz stock.. Planning to overclock.
Hard drive: $100 TOSHIBA DT01ACA100 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal HD
Graphics card: $180 GeForce GTX 560 (Fermi)
RAM: $50G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM 1600 Desktop memory
Optical drive: $50 Blueray reader, dvd/cd reader writer
Motherboard: $220 Intel BOXDZ77GA70K LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
CPU fan/ heatsink $35 COOLER MASTER Hyper N 520 RR-920-N520-GP 92mm Sleeve CPU Cooler
Case: $100 Cooler master Black Steel + Plastic and Mesh Bezel ATX Mid Tower
PSU: $90 Rosewill HIVE Series 750W Continuous @40°C
OS: $0 linux
Moniter: Around 20" LED HD moniter, probably bought locally.
Speakers: Some kind of 2.1 system around $50
Keyboard/Mouse: probably something local, unless something online catches my eye.
-------------------------Questions-----------------
1. How much will switching from a 7200 RPM drive to a 10000 or 15000 RPM, or a SSD drive improve performance?
2. Would it be worth the extra $100+ to go from an i5 to an i7?
3. With this set up, how much will I be able to overclock the cpu?
4. Am I correct in believing that the mother board has onboard wifi? It says it has Intel 82579 as a lan chipset, and intel 82574 as a secondary lan chipset. What does that mean?
5. Is the psu under or over powered? I couldn’t really find any information about how much power most of the components use.
So its going to cost around $1200-1300 dollars. How good of a computer is this? How long until it will be so far out of date that I just need to scrap it and start over?
If I wanted to go far budget, how much would a cheap gaming computer be?
EDIT: I was planning on runnning SLI when an upgrade was needed, or as i got the extra money.
OS: $0 linux
