I just recently ordered and received this power supply:
Topower TOP-1000WG 1000W:
http://www.newegg.com/Product/Product.aspx?SID=eiSjhFD6EeKjxDoMloNEXAsBl6_UhhM3_0_0_0&AID=10440897&PID=1225267&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-cables-_-na-_-na&Item=N82E16817342041
and im confused about why they would make a power supply that can produce a 1000 watts but only allow 19a for peripheral devices.
According to this review from tweaktown:
http://www.tweaktown.com/reviews/4178/topower_top_1000wg_1000w_power_supply_review/index4.html
It states: "12V1 handles the 20+4 pin Main connector and all of the peripheral connectors." So basically from what i can gather, my video card and any other devices i hook up will be drawing off the same 19a rail. So the video card i have now requires 24a or above, so theres no way i could do sli with this power supply let alone power what i have now from what i understand. Why would they split it up like that? I will never use the other connectors that are allocated to the other rails, so essentially is it a waste of capabilities?
Should i return this one and find a power supply that has all the amps on one rail instead of split up so pointlessly?
