Tom's Hardware > Forum > Mobility Brands > Nokia > HELP::bluetooth connection problems with nokia 6600 wit
Forum Mobility Brands : Nokia - HELP::bluetooth connection problems with nokia 6600 wit
Archived from groups: alt.cellular.nokia (More info?)
I have a 6600 and I was trying to connect it to my computer via
BlueTooth
that works.When I try to use the PCSuite, the bluetooth connection choice
is
there but not Connection and so I cannot sync the phone with my PC Suite
for Nokia 6600 .Can anyone give me any suggestions of how to set it up? so
if there is other software that i need to use can someone please help me
out
Many thanks
No1Badboy
Sponsored Links
"No1badboy" <No1badboy@power-post.org> wrote in
news:5C5Wc.191168$28.109686@fe1.news.blueyonder.co.uk:
> BlueTooth
> choice is
> Suite for Nokia 6600 .Can anyone give me any suggestions of how to set
> it up? so if there is other software that i need to use can someone
> please help me out
> Many thanks
> No1Badboy
Try Mrouter 3 Beta...that will help you connect easier and just install
it over your existing PC Suite...
Mrouter 3 Beta can be had here;
http://www.intuwave.com/index.php?page=105
Oh and it also connects automatically when your phone comes within
bluetooth range ;)
cheers ;)
Reply to a_dude
Try the following:
- in m router check the port which the bt software installed for Local
services (you can see it by right clicking bt icon and choose advanced
settings), in my case it is com4
- in nokia connect manager choose the com port that the bt software
installed for Client applications (you can also see it in adv. settings) in
my case com5
It should work, in my case did, after trying and trying.
Good luck.
"No1badboy" <No1badboy@power-post.org> wrote in message
news:5C5Wc.191168$28.109686@fe1.news.blueyonder.co.uk...
> BlueTooth
> is
> out
> Many thanks
> No1Badboy
Reply to Andy
Make sure any internal modem is disabled.
> BlueTooth
> is
> out
> Many thanks
> No1Badboy
Reply to Hunter
"No1badboy" <No1badboy@power-post.org> wrote in message news:<5C5Wc.191168$28.109686@fe1.news.blueyonder.co.uk>...
> BlueTooth
> is
> out
We can suggest to have a look at Oxygen Phone Manager for Symbian OS
phones ( http://www.opm-2.com/symbian/ )- another multi-functional
software for Symbian-based smartphones management.
Don't forget to install its agent (opmagent) as specified in 'Help'
option of main menu!
If you have any questions and/or suggestions, concerning our
program, feel free to post them on our official forum
http://www.opm-2.com/forum/
Best regards, Maxim Vyalkov
Oxygen Phone Manager - all you want from your Nokia
support@oxygensoftware.com
http://www.oxygensoftware.co.uk/
http://www.smsactivex.com/
Reply to Anonymous
There are 762 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
