Hello so this is the gaming build ive been thinking about some things may go a bit far and some not so much. I want to buy all the stuff from one source Newegg. Dont want to go above 1550$ this will cost ( i think ) 1200-1300$) probe alittle over counting shipping and handling.
Corsair Carbide Series 300R Black Steel / Plastic ATX Mid Tower Computer Case
MSI 990FXA-GD80V2 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
XFX Double D FX-787A-CDFC Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
CORSAIR HX Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
AMD FX-8150 Zambezi 3.6GHz Socket AM3+ 125W Eight-Core Desktop Processor FD8150FRGUBOX
SAMSUNG 830 Series MZ-7PC128D/AM 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) Desktop Upgrade Kit
CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9
seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
My goals: Have an awesome Gaming PC at the start, Have a great amount of upgrade space for the future so i can keep this computer awesome for what i want.
Questions: This mobo... it will be able to do crossfire right? The video card could be better but can it run Arma 2 maxed out ive searched for the answer but have not found one... . Am i forgetting anything? Thanks for any help please if you want me to change something tell me why.
Most of all let me know how well this build will work for my goals
