My friend wants an affordable graphics card that will run battlefield 3 pretty well and asked me to make a recommendation, he doesn't want to spend a lot so from my research it seemed like this card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625 would be a pretty good deal at just 115$ the only problem I'm having is that I'm not sure if his comp will be compatible with it. he has a 500w power source and this motherboard(http://www.newegg.com/Product/Product.aspx?Item=N82E16813131669). I'm positive that a 560 wont work and I'm pretty sure it's due to the wattage so it seemed like this particular 550 would be a solid card that should work but I'd like some opinions and also some confirmation on whether it will work or not.
