Hello, I just bought the H70 CORE corsair liquid cooling system for my FX CPU and while in the process of installing it i was in the final stages where all i had to do what just snap it on to the bracket and it wouldnt fit.... I found out that the clearance needed to screw in the screws but still have it attached isnt there. Am i just doing somthing wrong, did i just get a bad part? I have checked over the (very vauge) instructions multiple times and i have done everything correctly. So am i just making a rookie mistake or is this somthing wrong with corsair?
