HD-problems after CPU-upgrade. I'm desperate!
I'm desperate for help, so please try to help me...
I'll give you the whole story.
I have a K6-2 350MHz system with two IBM harddrives, one 8GB (primary slave, D:) and one 30GB (primary master, C:).
I decided it was time to upgrade the system and bought a T-bird 1.33GHz, Abit KG7-LITE, 256MB DDR DIMM and a Chieftec Dragon MidiTower.
Since this upgrade probably would require a reinstallation of Windows 2000 I decided to format the whole drive to get a really clean installation.
Therefore I copied everything on my 30GB-drive that I really needed (mp3, divX, games, appz, documents, drivers, etc.) to the small 8GB drive just for temporary storage while I sweeped the "main-drive" clean. I managed to fill the entire disk - 8GB of data that has taken years to gather.
I had FAT32 on both disks and both Windows 98 and Windows 2000 installed on the C drive.
After installing all the new hardware I booted up (and adjusted the necessary BIOS settings) and chose Windows 98 in the boot menu, I hit F8 and started only DOS. I switched to D: and typed "format C:" and the whole process went quite painless. At this time both drives were functioning perfectly, the backed-up files were all on the D-drive and all was normal.
After formatting the C drive I rebooted the system with the Win2000 CD in the CD player, and the Win2000 installation started.
Already at this point did I notice something strange - in the beginning of the installation, when you are asked on what drive you want to install the OS, both harddrives were listed, BUT the "backup-drive" was listed as errornous. I don't remember _exactly_ what it said 'cuz I didn't think it would be a huge problem, so I went on with the installation and all went just fine.
When I was done I opened Windows Explorer to re-locate all the files from the 8GB backup drive, and to install all software I had there, etc. It was no good... *sigh*
The D-drive was listed as "Local Disk (D:)" and when I tried to open it a message told me that the harddrive was not formatted, and asked me if I wanted to format it. Naturally I chose NO, 'cuz I KNOW it is formatted. Geez, it's FULL of stuff that I can't possible afford to lose...
What am I to do?!?! What went wrong, and more importantly, how can I save my data???
Quote from the Boss: I didn't say it was your fault. I said I was going to blame it on you.
4 answers Last reply
More about problems upgrade desperate
  1. I'm very sorry, don't have time for details,
    Just don't worry, you have to add your HDD.
    Later.
  2. okay... don't exactly know what you mean, but I'd _really_ appreciate if you could help me... I really don't want to lose everything stored on that disk...
  3. Try booting to a Windows Startup disk (ie Win 95, 98, or ME) and checking fdisk. As long as it's assigned a drive letter, goto the drive letter and do a directory listing on that drive. If you see your files there I would load Windows 98, Backup your data, and reinstall Windows 2000. Once you have Windows 2000 loaded repartition and format the drive ...
    Hope that helps?
    <font color=red><b>"Can you deal with that!"</b></font color=red>
  4. Hey! That's exactly what I did last night! (:
    The problem was I didn't have a Win98 bootdisk, but I got one from bootdisk.com and once I had booted with the disk the D drive was accessible. Hence I could install Win98 from there and copy everything to the main drive (C:).
    The weird thing is that when I then reinstalled Win2000 it still couldn't read the D drive... When the installation program asked me on what drive I wanted to install W2k it listed the 8GB drive as "Unformatted or damaged"...
    But this time it didn't really matter since I had already copied all the files to the main disk...
    Thanks for all help and advice! I'm eternally grateful (:
Hard Drives Storage
