AMD A10 5800K 4.5 cinebench problem
well this is strange i was doing some cinebench tests and i found a picture on a site with the same cpu and ghz as mine
this is my cpu ONLY 2C/4T ??????? my ram is running on 2400mhz forgot to add it in the pic
http://img62.imageshack.us/img62/4148/32682415.png
and this is his score cinebench shows 4C/4T
http://i76.photobucket.com/albums/j37/clon22/Extended/FM2_A85AX_G65/45ghz_ciniebench64.jpg
11 answers Last reply
More about 5800k cinebench problem
  1. i dont know what 4c/4t or 2c/4t is can u explain please
  2. c = cores
    t = threads
  3. It's to do with how different versions of windows identify the core/threads
    i'm assuming your running Win8 which shows 2core (2 modules) / 4 threads
    While the other guy is running Win7 which see's it as 4cores / 4 threads
  4. 2 cores/4 threads is what you want to see, anyway - it means the scheduler will load up each individual bulldozer/piledriver module fully before hitting the second core on any individual module- which is going to be faster in lightly threaded loads like gaming.
  5. Can you tell me how you get Cpu-z to show Core Voltage instead of Core VID? and whats your voltage setting for 4.5Ghz?
    my voltage is 1.51875 and i didnt change any settings in cpu-z
    Ok thanks am about to change my Mobo anyways. i have the same APU but i pair it with an HD 7770 and disable the integrated graphics
  8. having problems with my voltage settings, here is my tread
    http://www.tomshardware.com/forum/282856-29-5800k-core-voltage-problem#t2034840
    maybe you can give me some pointers?
    why did you disable the igpu and does your mb support virtua mvp??
  10. Its disable because i have the HD 7770 and no it doesnt support virtua mvp
  11. The program identifies the A10 58XX as being a 2 module processor with 2 cores and 4 threads. This argument has been done into the ground and even AMD have come out to explain the nature of the module architecture, suffice to say AMD deem it a 4 core processor with 4 active Threads.
    I would not be worried about it, its still a 4 Core APU irrespective of software identification.
CPUs AMD
