My laptop is a gateway p-173xl fx laptop and I'm having trouble with my Video controller NVIDIA® GeForce® 8800M GTS, it originally came with a windows vista 64bit OS and i upgraded to windows 7 64bit awhile back and i reinstalled it recently and afterwards it comes up as standard vga adapter under device manager, I have also tried updating it to the latest nvidia update for the 8800M GTS and it says there is some hardware issue. Any help would be greatly appreciated.
SPECS
Processor Intel® Core™ 2 Duo processor T8300
2.4 GHz | 3 MB L2 Cache | 800 MHz FSB
Chipset Intel® PM965
Display panel 17-inch Ultrabright™ WXGA+ TFT (1440 × 900)
Memory 4096 MB 667 MHz DDR2 SDRAM (2 × 2048)
Operates at 667 MHz
Total slots: 2 DDR2 slots | Available slots: 0 DDR2 slots
With 512 MB of GDDR3 Discrete Video Memory
Audio High definition audio - 2 channel
Webcam 1.3 Megapixel
HDMI port Version 1.2
E-SATA port Yes
Fingerprint reader UPEK silicon based fingerprint sensor
Hard drive 400 GB 7200 RPM SATA hard drive with Raid 0 (2 - 200 GB hard drives)
Optical drive 8x Multi-Format Dual Layer DVDRW with DVD-RAM and Labelflash™
Write maximum: 8X DVD±R, 6X DVD-RW, 8X DVD+RW, 2X DVD-R DL, 2.4X DVD+R DL, 5X DVD-RAM, 24X CD-R and 16X CD-RW discs
Read maximum: 8X DVD-R/RW/ROM, 4X DVD±R DL, 5X DVD-RAM, 24X CD-R/RW/ROM discs
Modem Integrated V.92 56K modem
Network Integrated 10/100/1000 Ethernet adapter
802.11n wireless LAN Bluetooth® 2.0
Memory card reader 5-in-1
Memory Stick®
Memory Stick Pro®
Multimedia Card™
Secure Digital™
xD-Picture Card
MiniSD and RS-MMC (when used with adapter that is supplied with card)
Interfaces
Three - USB 2.0 ports
One - VGA port
RJ-11 port (modem)
RJ-45 port (LAN)
One - E-SATA
One - IEEE 1394
Headphone/SPDIF audio out jack
Microphone jack
One - HDMI V1.2 connector
One - Kensington lock slot
Power input
Pointing device Touchpad with vertical scroll zone
Expansion Slot ExpressCard™ Type 54
Battery 9-cell Lithium-ion
Dimensions 1.3 to 1.7-inches (H) × 15.75-inches (W) × 11.75-inches (D)
Weight 9.2 lbs (14.01 lbs)
SPECS
Operates at 667 MHz
E-SATA port Yes
Memory Stick®
Memory Stick Pro®
Multimedia Card™
Secure Digital™
xD-Picture Card
Interfaces
One - VGA port
RJ-11 port (modem)
RJ-45 port (LAN)
One - E-SATA
One - IEEE 1394
Microphone jack
Power input
