Sign-in / Sign-up
Closed
Power supply Cable splitter/y cable?
  • Power Supplies
  • Graphics Cards
  • Power
  • Cable
  • Components
  • Product
Last response: in Components
December 29, 2012 2:09:48 PM
I Recently bought a PCIe Video card (type not important), and it requires 2 4-pin power connections. It came with a y cable that turns 2 of said 4-pin power drops into 1 6-pin power source for the video card. That is all well and good, but I also need another 4-pin power drop for my CD/ROM drive. This is a Desktop Computer.
Is there a cable that can turn one 4-pin power drop into 2?
EDIT: the connections That I refer to as "4-pin" are molex power connections. just thought I should clear that up. :)
More about : power supply cable splitter cable
December 29, 2012 2:15:29 PM
I have to work until 5:30 today. I'm not ignoring you guys, just at work. :)
Score
December 29, 2012 2:29:39 PM
You should be able to get it from your local PC shop or PC World or Maplins (prices will vary)
Des
Score
December 30, 2012 12:55:33 PM
ok. thank you. I found the same cable on amazon.
Score
December 30, 2012 12:55:57 PM
Best answer selected by mryan2.
Score
