Compatibility Of Components & Motherboard Help
Last response: in Systems
August 14, 2012 7:54:57 PM
Can anybody help me by telling if all these will be compatible and also help me choose a motherboard . Shud i get a different motherboard or not ? Also should i get a 600W power supply instead of 700W ?
1. COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
2. EVGA 025-P3-1579-AR GeForce GTX 570 (Fermi) HD 2560MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
3. COOLER MASTER Silent Pro M700 RS-700-AMBA-D3 700W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Modular ...
4. G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR
5. ASRock Z77 Pro4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
6. Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770K
I need the processor for gaming as well as some editing so i think i7 3770k will be good and also it would be good for future as it can be oc'ed .
As for the motherboard i need wifi on board too so i will get Asus p8z77-v .
Now i cant decide whether i shud get Gtx 670 ftw or DcII Top or Gtx 660 Ti .
a b V Motherboard
August 14, 2012 8:30:24 PM
What's the budget and primary use?
If it's gaming - Cooler Master is horrendously unreliable when it comes to power supplies. The i7 isn't needed. Drop that to the i5-3570K and upgrade your GPU to the GTX 670. The 570 is pretty much a moot point anymore when the 670 is far superior and the 660TI is due any day now.
As far as a motherboard I'd suggest this: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
I'd also suggest this for a case: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
The HAF 912 is good, but this will be better.
m
l
August 21, 2012 9:57:33 AM
Thanks a lot for the suggestions .
m
l
