Help Choosing a GPU ?
I am a complete noob, and I'm sorry if this question is ridiculous but I simply don't know enough to choose on my own.
I am building a rig for doing some video editing ( after effects ) some 3D work ( Maya, 3DS max) and i will probably be running 2 monitors. My budget for the whole computer is around 1500$, so for the GPU i would like to spend 200-400$.
Thanks for any help!
3 answers Last reply
More about help choosing
  1. GTX 670 fits into your budget that all you need or want.
  2. if it is based on 3D work i recommend you looking for a Quadro GPU:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814133272
    or
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814133353
    if it is for gaming, the 670 will be awesome.
  3. get a gtx 570, it is supported generally and can perform as well as more expensive quadros. It also does much better than the new 6XX in none gaming applications. You should be able to get one for less than $300.
Graphics Cards GPUs Video Editing Graphics Product
