Hi
I built myself a new system about 8 months ago. This was my first ever attempt and although a few things were a bit tricky all seemed to go well and I have been very happy with the machine, however over the last few weeks I've been having power issues. I imagine it must be the power supply but I'm not sure how to go about isolating things other than my very layman approach so far.
So, what has been happening is that most of the time now when I press the power on button nothing happens. If I then go to the main 'rocker' switch at the back of the case and flick it on and off, if I am lucky the system will fire up after a few attempts. Sometimes I can be trying for a few minutes of flicking on and off before it sparks into life. Until a few days ago once it is on everything is fine. O/S is stable. Runs like a dream. However, a couple of days ago and again tonight, the power cut out as if the mains had been switched off. I took the power out and left it for a while then tried my normal procedure of switching from the rocker, but this time after about 10 minutes, no go.
What IS happening though as I am switching on and off from the rocker, is that occasionally as it goes to the on position, everything sparks to life for an instant but then goes off again straight away.
Another thing to mention is that ever since I put the machine together the power supply fan has never spun up. I did read up on this when I first put it together and read a few posts (not sure where now) that this was actually normal as the machine was not under stress. So I discounted it as an issue.
I figure I've got a loose connection, but maybe inside the power supply, rather than the power supply being dead, as it does fire up after a while, normally, but wondered if anyone else has had a similar problem and can share what things I should try.
Many thanks,
Martin
Spec
- Corsair Graphite Series 600T Mid-Tower Gaming Case
- ASUS 1155 P8Z68-V PRO S/L
- Corsair CMPSU-850AXUK Professional Series Gold 850W Power Supply
- LG BH10LS30.AUAR10B 10x Internal Blu-Ray BDRW Retail Kit
- Corsair CSSD-F120GB3-BK Force Series 3 120GB Solid State Drive
- Western Digital 2TB SATA 6Gbps Power Saving Internal Hard Drive OEM - Caviar Green
- Corsair CMZ16GX3M4A1600C9B 16GB (4x4GB) 1600MHz CL9 DDR3 Vengeance Blu Memory Four Module Kit
- Intel Sandybridge i7-2600 Core i7 Quad-Core Processor (3.40GHz, 8MB Cache, Socket 1155)
- Thermalright Venomous X RT - Processor cooler
- Sapphire 11180-00-20R HD6850 1GB GDDR5 Graphics Card
- 1 x BenQ BL2400PT 24-inch W LED 1080p Monitor
- 2 x Viewsonic VX2260WM 22" widescreen 2ms LCD TFT Monitor
- OS Win 7 Ultimate x64
Many thanks,
Martin
Spec
