Hello everyone,
I am experiencing an odd issue that I have never encountered before. When I FIRST come home from work and power up my PC , it looks like it is 100% operational (all fans moving and all lights on) however I get no display and I noticed that my Razer Nagga Mouse and Logitech g510 keyboard do not light up as usual nor is the LCD screen operational on the keyboard. The monitor goes through the cycle of checking all ports before going to sleep. If I hold down the power button to do a manual shutdown and then simply press power once again , everything loads 100% normally. It loads as fast as it ever did, but not until I power it up once , manually shut it down via button and then power it up again.
I built the computer piece by piece from an HP tower, all that remains from HP is the 2nd HDD and a heavily modified case. Here are the specs if it helps.
MoBo: MSI 890GXM-G65
8GB DDR3 1333mhz
Phenom IIx4 630@2.8ghz (OC'd @ 3.4) Dual Fan copper heatpipe cooling
MSI GTX560-ti Twin Frozr II
OCZ Sata III 256 GB SSD - WD VelociRaptor Sata III 600GB HDD - Stock(forget what brand) 500GB HDD
I have checked my connections several times with the HDMI cable, I have tried powering the monitor off and then on. This has been happening for about a week now , everyday without fail. I always shutdown from windows if possible via selecting start>shutdown.
8GB DDR3 1333mhz
