TV as Monitor problem HELP!
Hey I need some advice, I am using my Samsung 40D6500 LED tv as a Monitor. When I set the display to Native 1080P resolution in the Nvidia centerTX 670
4 answers Last reply
More about monitor problem help
    Please post your question in the form of a complete sentence.
  2. I am gonna guess he is gonna ask when he sets the resolution to 1920x1080 part of the image is cut off on the screen...this is because you have your tv aspect ratio set to something like 16:9...to fix this change the tv aspect ratio to just scan this doesn't alter the incoming image it just displays it directly
  3. I'm not sure how my question got cut off, but yes that was what I was asking drums.
    I found out there is HDMI. I have to run it to the TV with VGA, then I can adjust the TV to PC Monitor.... Gay
  4. it shouldnt matter if its hdmi or vga....just make sure the aspect ratio setting is just scan for either input and it will not cut off the image at all
Graphics Cards TV Monitors LED Monitor Graphics
