Solved
Advice on replacing power supply
I've had this computer for about 2 years: http://www.newegg.com/Product/Product.aspx?Item=N82E16883229221 only adding on another 6870hd card for crossfire and replacing the ram.
Since I got it I've been experiencing constant freezing/blue screen issues like the numerous other people that have gotten cyberpower pcs. It turns out the crappy Xtreme Gear Psu may be causing it.
I need advice on what new power supply to get and how difficult is it to replace the power supply.
11 answers Last reply Best Answer
More about advice replacing power supply
    Hi - What is your PSU budget & where are you located?
    Tom
    Tom
    Under $150~ I'm in the U.S
    OK - give me a couple minutes.
    Good news is you won't have to spend $150.
    You are using 2 - 6870's in CF right?
    Yes
  5. Best answer
    Hi again - realhardtech on their PSU req for 2 6870's in CF is 900w.
    You don't need that much, you could probably get by with a
    quality 750w unit, I'm going to suggest at least one 850w unit
    to be on the safe side.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151108 nets to $120
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151102 nets to $140
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139022 nets to $130
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817182084 nets to $110
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021 nets to $100
    Any of these will power your sys with 2 - 6870's in CF. My personal pref of these
    is the Seasonic X-850
    How difficult is it to change psu's?
    Hi - not difficult at all. I consider myself lousy at mechanical stuff
    and I changed mine. There are tutorials online, there are also
    demo's of how to do it on you tube.
    Here is the one I used:
    http://www.hardwaresecrets.com/article/362
    Tom
  8. Best answer selected by zentaki.
    nnHi again - plz - no need for the 850 - save some $$ the psu reqnI was looking at didn't seem right, so I dbl checked andnthe 900w was for 6870x2 & CF (so 4 cards, not 2).nnGo with either of the last 2 I linked & they leave a lot of headroom.nSorry, for the screw up.nnIn fact you could be OK with a quality 650w unit.nnnTomnnlet me know if you want me to find a 650w unitnnhttp://www.newegg.com/Product/Product.aspx?Item=N82E16817207022nnhttp://www.newegg.com/Product/Product.aspx?Item=N82E16817139020nnhttp://www.newegg.com/Product/Product.aspx?Item=N82E16817207014nnn
    Tom
    It's all good, the 850 is perfect for future upgrades I may get.
    OK - just wanted you to have the right info, I have a Seasonic X series,
    outstanding PSU's.
    Tom
    Good luck with your rig
Power Supplies Computers Crossfire Components
